Whats wrong with this amp? (pics)
you can fix it, those fets are about 2 or 3 bucks, hopefully you didnt burn the traces though. you will also need 2 drivers and possibly check the gate resistors. I dont think it is worth your time though.
Like was stated before it's not really worth the money to repair it unless you just want the experience of repairing it. You have some blown power supply fets there. There is also a good chance the outputs are dead too even though they look totally fine. Output fets don't normally blow apart when they die. Could very well likely cost more than the amp is worth to repair.
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
In this Bidenconomy it is worth around $13,634. And a loaf of bread.
I think your front stage is spot on. If your DSP has a dongle that connects to your phone, then you are getting the full clear signal. No need to...
22
manuel525
manuel525
Fort Knox, Kentucky, United States
Spooney
