What do I need to run 6.5 in 300W Mid-Bass woofers?
Lancer521
I have almost no experience with car audio, so please don't talk technical, help me out by explaining and using links.
I ordered some PYLE PLG64 6.5 in 300W Mid-Bass woofers - I know they're cheap, but because I know little I figure they are a good start. They'll be mounted in the rear mounts (over the trunk). Here are the specs:
Yellow CD P.P. Cone - Magnet Weight: 30 Oz
Specially Treated Rubber - Impedance: 4 OHM
Edge Suspension - Rubber Magnet Boot Cover
1.0'' High Temperature - 300 Watts Peak Power
Aluminum Voice Coil - Mounting Depth: 2.84"
I'm using a Pioneer AVH5700DVD deck with these specs:
Power Per Channel 50 Watts x 4 Channels
Pre-Amp Outputs 3 Channels
Input Connectors RGB x 1, AV x 1, AV-Bus x 1, Camera x 1
Output Connectors AV x 1
What do I need to get the low frequencies out of these speakers? Do I need an Amp? If so, what should I look for?
I am out of the car audio world the more my ears age. However, I am very much still a hobbyist in the electrical field. With much of my current...
15
So you're planning on running active and using the amp or head unit crossover for the tweeters? Is that sub channel full range and have separate...
983
Lancer521
Lancer521
Logan, UT
SicAudio
