COMPLETED SQ Q1-3500D.1 Amplifier
  • 5
Digital Monoblock 1 ohm stable
Input Sensitivity 0.2V ~ 5V
Variable Low Pass Filter 20Hz ~ 200Hz @ 24dB/Slope
Subsonic Filter 10Hz ~ 50Hz @ 24dB/Slope
2 amp linkable connection Output Master / Input Slave
Clipping Display Led On Remote Gain Control
Signal to Noise Ratio 85dB
Damping Factor 250
Efficiency 85% at 4 ohm
External Fuse Rating 380 Amp in-line, 760 for pair
Tested Voltage 14.4V
Working Voltage 9.5V ~ 18.5V**
4 ohm power @ 12V @ 1% THD 750W x 1
4 ohm power @ 14.4V @ 1% THD 1400W x 1
2 ohm power @ 14.4V @ 1% THD 2600W x 1
1 ohm power @ 14.4V @
1 ohm Power @ 16V** @ 1% THD 5300W x 1
1 ohm Power @ 18V** @ 1% THD 6000W x 1
1 ohm Power @ 18V** @ 10% THD 7500W x 1
2 ohm Linked Power @ 14.4V @ 1% THD 8600W x 1
2 ohm Linked Power @ 16V** @ 1% THD 10600W x 1
2 ohm Linked Power @ 18V** @ 1% THD 12000W x 1
2 ohm Linked Power @ 18V** @ 10% THD 15000W x 1
Dimensions (mm) 657.2mm (L) x 241.3mm (W) x 66.7mm (H)
Dimensions (in) 25.875in (L) x 9.5in (W) x 2.625in (H)
Power and Ground Inputs 0 Gauge x 2
Ran @.5ohms daily on good electrical. (245A Alternator, 330Ah total)
$600 + Shipping (71459) (30lbs)
Pictures:
Cus I need cash. Selling my whole system. I'll keep the amp. Just go with one hdc3 15 but I need the cash. Why have a system if your car is immobile
I pray you still have this when i get these amps sold!
@dub you must need one to match
@nutdawg maybe. i just need cash to fix a my car. if i come up with it by some other means then ill keep the amp. until then, its on the market.
yeah I need one to match so I can strap them until I get the money for the power I really need
wait.... whats wrong with your car? I work at a garage here in Shreveport and I do tons of work on the side.... maybe we can work something out??
Yeah, like Audiobaun said, big amplifier likes a big car battery and a strong alternator. If you wire your subs to 1ohm, you want to have an idea...
875
Like @maylar said, delay the turn on to the amplifier only. 3 to 5 seconds should take care of it.
423
Google and Ebay are your friends. Froma quick search and providing these are like new, $2- $400 for the subs and $2- $400 for the amplifiers...
The CT's are nice, That Sundown is a a frik'n beast!
882
BamaBoy334
BamaBoy334
Louisiana
BamaBoy334
