Kenwood DMX-5020 Carplay stuck in dark mode
  • 2
Alx27
I have just installed a Kenwood DMX-5020 and it's stuck in Dark Mode and automatic has no effect, other than to occasionally flicker into light mode for a split second.
The Phone (X) is running the latest iOS available: 16.7.5. Tried an iPhone XS on iOS 17 - no different. The Kenwood is running the latest firmware 22.12.2022
The iPhone is not in dark mode itself and toggling it has no effect. This has been tried: "Go to settings, then “Privacy”, then “Location Services”, scroll all the way down and go to System Services. Make sure to turn on “System Customization” and “Setting Time Zone”. Apparently this allows the interface to switch between dark and light based on location." The clock on the Kenwood is also correct.
You can switch to day mode in Google maps, but automatic just keeps it in dark mode.
Video:
(FYI the DMX-5020 is the same unit as the DMX-4707)
Another issue is that the sidebar position is greyed out in the menu
Hi Ferdi.. Yes I have had a brand -new DMX5020 installed last week and it does almost as you described. Once the phone is connected it's all...
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
442
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
721
Alx27
Alx27
Manchester
Jimi77
audiobaun
    May 19, 2024
    May 19, 2024
