I need help with my amp
  • 5
I quit taking the stuff years ago!!!
Jk, can you provide a picture of what you think it is that you're looking for? Which amp, where/what connectors on that amp?
Where to I get connectors for my thump amp they look like circles and squares in one hole plug it's so I can connect me sub to the amp
Does the connector on the amp look like it will couple any of these harnesses?
885
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
shawn mrtll
shawn mrtll
Alpena
Jimi77
