Head unit snagging - using Connects2 interfaces.
  • 2
Geoff.C
Hello,
I am a relatively competent DIY fitter, but have run into a snag that I would appreciate some help with please.
I am upgrading the head unit in my Fiat Ducato based camper, and am currently fitting a Pioneer SPH-EVO950DAB unit.
I have sourced an interface kit (with new fascia) from Connects2.
Within the kit are a 'Male Fakra to SMB Female Antenna Adapter' and a 'Fakra to DIN Aerial Antenna Adapter'
Both of these connecters have a thin blue lead with a metal clip on the end (see photo below).
I am guessing that this is a grounding lead, but the connection on the end of the lead does not appear to be very strong, and I am not sure where to connect it.
I currently have it clipped to the head unit chassis, but the DAB signal is rather flaky. The connection does not feel very secure, and I think I have probably got it wrong.
Can anyone advise me where / how this should be connected please ?
Many thanks
Geoff
Loose grounding could cause the spotty issue. I would find a good existing screw that is mounted to the back of the internal dash wall. Remove it, sand down the area and crimp a ring terminal or spade onto that accessory and screw it down good and tight. Changing the connector to a ring or spade terminal is key, could try and ground it to the same ground as the HU preferably.
EDIT:
My apologies, I hadn't finished my morning coffee! That solid blue wire is a power lead, not a ground.
Thanks for that - Do we think that the connection is a grounding lead ?
My apologies, I hadn't finished my morning coffee! That solid blue wire is a power lead, You will connect it to the blue/white remote or the solid blue antenna turn on lead from the harness you are using.
My apologies, I hadn't finished my morning coffee! That solid blue wire is a power lead, You will connect it to the blue/white remote or the sold blue antenna turn on lead from the harness you are using.
Brilliant ! - Thanks Doxquzme ...... that's exactly what I needed to know.
Cheers !
388
693
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
757
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
934
Geoff.C
Geoff.C
Merseyside, UK
Geoff.C
just call me KeV
    Jun 2, 2024
just call me KeV
    Jun 2, 2024
