Head unit smoking while trying to use DIY USB to Jack cable
Jeyes
Norway
Title pretty much says it all... And to start off I would like to say that I am totally new to car audio systems and I don't know anything, but here's the story.
I just got a new head unit but it didnt have an jack input, only a usb.
I wanted to test it out with some of my own music and not just listen to the radio... For that I obviously needed a cable - which I didnt have. I did have a jack and a usb, but they were seperate, so I cut them open and spliced them together.
The first problem was that there was no audio, but I kept on trying. Suddenly I started smelling something weird, but I didnt think much of it, until I saw smoke coming from the head unit. I quickly turned off the car and unplugged my awesome DIY cable (which took me an hour to make by the way). I took the head unit out and there was lots more smoke.
So obviously that didn't work at all, and I will have to go get a proper cable soon. But I'm wondering, what caused the head unit to start smoking? Could there be a voltage difference or something?
what the hell are you doing? do you understand that USB and aux are two completely different signals. would you go cut open an outlet in the wall of your house start splicing it together with a coax or ethernet cable. the amount of flak you're going to get is going to be tremendous..be prepared..
Well I figured that since there are USB to Jack cables I would be able to replicate it //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif But no...
dont feel bad buddy, ive done plenty of "MacGyvering", it doesnt always work out.
The ideas I have after 2 AM are rarely the best though, should have known something would go wrong //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Wall jack to ethernet cable is considered an outlet data cable used in situations such as dish network or directv to transfer internet services to all outlet data cables.
Sent from my draconis using Tapatalk
^^^ this guy
lol ok ******** we dont need another adulbrich. plus, the method you're referring to is if you actually splice the correct wires. I attempted to make it clear that splicing **** randomly will not net good results. dont confuse the guy, you know as well as i that he dun fucked up
This might be the best thread on these forums and there's only a dozen posts so far. Thanks for a good laugh OP! //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
I was going to ask why didn't you waste the 10 minutes to run to a walmart or radio shack.... Now I see your in Norway.
If it's already smoked it most likely fried that circuit already.
394
698
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
760
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
938
Jeyes
Jeyes
Norway
Tripn88
