SOLD FS Memphis 16-MC1000D and 16-ST1000D
Basic1906
I have 2 Memphis 1000d amps that I am selling for a friend. The 16-ST1000D asking $200 shipped and for the 16-MC1000D asking SOLD shipped. Both work great but has some scratches.
MC1000D
1100W RMS Class-D Monoblock Subwoofer Amplifier
Custom Black Pearl Finish
Fully Variable Low-Pass Filter: 50 - 250 Hz, 18 dB/Oct
Variable Subsonic Filter: 20 - 50 Hz
Bass Boost: 0 - 18 dB
Gold-Plated RCA Connectors
4 Gauge Power Wire Capability
Wired Remote Gain Control
Power and Protection LEDs
Thermal, Short Circuit, and Overload Protection
RCA Outputs: 1 Pair
Adjustable Input Level Control: 400 mV - 4V
Damping Factor: 300
DImensions: 13.4" L x 6.25" W x 1.7" H
Amplifier Specifications:
Number of Channels 1 - Mono
RMS Power (4 ohms) 300 watts x 1 channel
RMS Power (2 ohms) 600 watts x 1 channel
RMS Power (1 ohm) 1100 watts x 1 channel
Bridged RMS Power Not Bridgeable
Peak Power Output 2200 watts
Minimum Impedance Unbridged 1 ohm
Minimum Impedance Bridged Not Bridgeable ohms
THD at Rated RMS Power 0.75%
Speaker Level Inputs No
Preamp Outputs Yes - 1 pair
Built-in Crossover LPF(50 - 250 Hz), Subsonic(20 - 50 Hz)
Signal-to-Noise Ratio 95 dB
Bass Boost 0 - 18 dB
Fuse Rating 40 A x 2
ST1000D
I have plenty of Refs on here from selling and buying.
No offense but you can not compare apples and oranges. MC/ST > PR in IMO. The ST/MC is smaller and produces more power from what I can tell from rated specs. I have never had a PR series so I can not tell from hands on comparision.
Well, that is your opinion..but there's no noticeable difference. All are great amps, and I meant nothing negative by my post..your amps are awesome, we have a few at the shop that customers used everyday for years and they work flawlessly.
No problem man. Thought you was dumping my bad...//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
https://caraudiobargain.com/audio-apex-cab-22-car-amplifier-monoblock-2200-watts-rms/ Since these are back in stock they're really hard to beat...
And the most important thing you've learned in life up to this point is to get offended on behalf of other people on the internet in the attempt...
18
5K
So recently I bought a Memphis prx1000.1 and installed it to 2 rockfordfosgate r1s'. Both svc and 150rms 4ohm. I wired them to a 2ohm load to the...
Basic1906
Basic1906
Frankfort, KY
    Jun 3, 2024
