Best lithium for 14.6-15.3V charging
Water Bear
Question as per the title. Thinking the answer is LTO, even though my charging voltage can only get them to between 40-75% SoC. Can't go 5s as that charges at 14, but 6s charges at like 16.8 which is way above where I'm at. What do you guys do?
The voltage range is what I observe under max load and warm (14.6) to cold idle (15.0 - 15.3), depending on the volt meter. I've got several hooked up and all they report differently ("a man with many clocks never knows what time it is"). Mechman says charging voltage should be 14.8 warm and that's probably the reality.
As an additional question, how do you guys figure required Ah? These claim a 10c rating, so do you guys figure "I need 1600A of fusing, so 6s4p @ 10c = 1600 A burst should work"? Plus maybe another bank for headroom?
EnedThat's a possibility. Mechman sells +0.5V plugs. Then the concern would be that 15.8 might burn up the electronics. But if it worked, that would be an easy way to access LTO.
Edit: That's a nice truck in your sig. You still driving it?
The single cab? No it ended up taking out 3 cows in the middle of the night on a local hwy.
My 3500hd I still have.
Most all LTO will run great at 15.3v. I run mine at 15.4 daily, and turn it up to 15.8 for comps. As someone already mentioned, and I know to be fact from running them for 7+ yrs now, most LTO does not really benefit from charging past 15.8v anyways, in a 6S config. I have experimented all the way up to MAX voltage(16.8v) and back down to 15.2, and 15.6 to 15.8 is the sweet spot. BTW, I run a combination of 10ah Scib and 3.5ah pouch cells ...
People have talked about mixing cells to balance C ratings and AH ratings. So it's working for you, then?
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
327
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
484
I hear ya. There are so many good deals on speakers too. My kid is 16, so loud is better than SQ. LOL... I really like the sound of the PPI...
15
821
827
Water Bear
Water Bear
Atlanta, GA
    May 22, 2024
    May 22, 2024
