6 Speakers To 4 Channel Amp Wiring
  • 2
Tynan9180
Tulsa
Hello, I new to the forum and fairly new to car audio. Here to learn and understand setup selection and installation.
Going to currently work on what setup I have as of now and build up as time goes.
Currently I have :
Vehicle : 1984 Chevrolet Monte Carlo
Front speakers : 3.5 Cerwin Vega H735/2-Way/4ohm/30W RMS each
Rear speakers : 4x10 Cerwin Vega H7410/2-Way/4ohm/50w RMS each.
Amp : Cerwin Vega CVP1200.4D/1200w/4 Channel/2-Ohm Stereo, 4-Ohm Bridged Full Range/75Wx4@2Ω RMS; 55Wx4@4Ω RMS
I also have a pair of Cerwin Vega H7694 6x9's that I want to add to this setup...4-way/ 4ohm/75w RMS each.
I want to stick with the Cerwin Vega brand for my entire sound system.
I'm wanting to wire those 6 4ohm speakers listed to my 2-4 ohm 4 channel amp listed.
Will my amp power the 6 speakers without damage to the amp and/or speakers ?
With the specs given, which 6 speaker to 4 channel amp wiring diagram should I follow below ?
Example 1.
For clarity, why not example 2 ?
Example 2 is 2 ohm...my speakers are 4 ohm and amp uses less RMS wattage with the bridged 4 ohm full range operation...
Why shouldn't I bridge and use 4 ohm full range operation instead of 2 ohm stereo ?
Before just now receiving the 6x9's, I had a Kicker 6x9 wired like example 1 to my rear right 4x10...
That wiring blew both the 6x9 and the 4x10, and I think front right and rear right channels on the amp. Haven't tested the amp channels, but I'm sure they're blown...pushes out/up the good 4x10 speaker surface I have and stays there.
Someone mentioned I threw off the ohm's by adding that Kicker 6x9 and blew out the entire left side, amp channels and speakers.
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
842
I don't think it's that easy to answer "for a complete beginner". amp and speakers ratings are those peak or RMS? Are these already installed...
Wiring question....using four 4 ohm speakers and one 2 channel amp capable of 2.ohm load... Using 2 ohm stable 2 channel 4 ohm amp to power four...
Sorry, replied to the wrong quote. Should've been to Revelle's original question.
14
Tynan9180
Tynan9180
Tulsa
Tynan9180
just call me KeV
    Jun 2, 2024
just call me KeV
    Jun 2, 2024
