LOC to factory radio on a 2012 Audi A4
  • 2
I want to istall a LOC to my factory radio becuase I will be upgrading my factory speakers how is it done?
An LOC is only used when installing an aftermarket amplifier. It is what levels the high output signal from the speakers to a low level signal for the amp's RCA inputs.
If you are only upgrading the speakers and using the OEM radio/amplifier, you want to know the resistance of the OEM speakers and look for a sensitivity of 90dB and above on the new speakers.
Thank you so much for that clarification I didn't know that. I was going to go with Cerwin Vega H765C but seeing that the sensitivity is 88db for those speakers, I'll have to search for something with a higher db#. I'm also having a hard time finding a really good detail video on how to install them, if you have any suggetions I would greatly appriciate it.
Thanks for the link to this video, I've seen this one before but it's not for component speakers which is what I'm going to install and the part of installing to he component speakers was the crossovers... How to get to get the signal from the radio but I found one a little bit but ago that I think will help me figure it out. I really appreciate all your help.
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
154
Yeah tapping off the 4 gauge is typically fine. However, you need to fuse the smaller wire right by the 4 gauge at 1 amp (or whatever the small...
834
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
unfortunately no empties but a couple promising choices, out of town right now have to this weekend 1) Car Radio Switch, Climate Control System...
Abilan17
Abilan17
USA
Abilan17
    May 19, 2024
    May 19, 2024
