iPad head unit setup
  • 2
You need a HU/receiver. The mini is only the signal source in this scenario. You have to have a compatible device to use the signal provided by the Apple device.
Would a line driver with line outputs into my amps be ok? I would either do that, and use dsp amps or use a separate dsp processor from the line driver into my regular amps. My system will have a pair of 3 way components up front and two subs in the rear.
It is usually reserved for completely customer installs, but here is some info on using the iPad as the HU.
So I am planning to build a system in my Ford Excursion and can’t decide on whether I want to use an iPad mini with a sound processor behind it or...
154
553
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
657
Brax1942
Brax1942
Arkansas
    May 19, 2024
    May 19, 2024
