Rv headunit change
norman6
So I wanted to upgrade my old RV head unit. It’s an ancient Linear series. I bought just a cheap regular android radio off Amazon. Following the diagrams on old and new, I have power and functional headunit, but no sound at speakers. Amp keeps cutting off power. I also tried to bypass using the amp, and connect only non amplified speakers etc…. No luck any way I’m trying.
Is there a special way to make this linear series setup work with a regular car stereo headunit?
what ^ said. amp gain setting info, test tones are at the very bottom...
559
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
norman6
norman6
hamiltom
just call me KeV
just call me KeV
