Component or coaxial speakers to the back
Is it normal to peak lower in your vehicle then the tuning of your box? If I build another box tuned to 30hz. would it peak @ 27hz.?
That varies vehicle to vehicle. Your low frequency peak could be the combination of the lowish tuned box and the cabin gain lining up at that frequency.
Only way to find the cabin gain is to subtract the frequency response of the same enclosure outside of the vehicle.
Usually you should do this first before designing the box so you can manipulate the box to work with or around the cabin gain.
If you have a low end peak in you cabin gain you could potentially tun you box higher than normal to have a more flat response higher into the frequency range.
A high end gain might require you to tune ultra low to get low bass.
Every vehicle is different and every time you add significant deadener or make a big space consumption change you should do a new test.
Adding a 10ft³ elcosure in the back of a Tahoe is going to change your cabin gain similarly, sealing off the trunk changes cabin gain, minor deadening doesn't change much but going from no deadener to fully treated is enough of a difference to warrant a new test.
You don't have to dive deep into the weeds I only recheck when I make massive changes in my system.
I have zero sound deadener in my truck. I also think I lost a db when I had to change out my back window. Thanks for the info.
It's my daily and don't have time to rip it apart. It also takes two people to remove my bench seat. It's cool that it's a daily work truck that isn't sound deadened. I've competed and won with my tools in the back and the pockets in my door panels full of "stuff."
I've never tried to compete with my dually it's more of a sql build than an spl build. I damn sure don't run the level of mid and high everyone is running these days. 2-4 pa mids per door and super tweeters all over. Gives me a headache just thinking about it.
I’ve tried it in 3 different vehicles and multiple locations. Rear deck is best for me. Unless it’s a midbass I don’t want anything in the rear...
Crutchfield can tell you what speaker will fit your car. for subs, Image Dynamics and Adire are still around. my last sub i bought was from...
960
I’m sure they will be a good budget setup. I think they will lack some midbass but door treatment is super important so definitely be sure to do...
wmbt02
wmbt02
Estonia
Bobbytwonames
